424
[Others] Is it ok to connect the SCL/SDA pins of 2 breakout boards to the same Raspberry Pi (3B+)?
Hi, I hope to connect a LSM303 magnetometer breakout board to a Ras Pi 3B+ that already has a Adafruit 16-Channel PWM/Servo HAT attached. Can I solder the I2C connections of the Magnetometer to ...
Raspberry-Pi
breakout-boards
SCLSDA-pins
Jul 29,2020
Joson
can you make the drawing and the cnc machining for a project I need but I don't have drawing ?
Maximum Dimensions of 3D metal part
POM Gear Wheel production large size M 2,5 280mm diameter
FREHD project
Question LED, backlight and LCD
Looking for Components Library + availability.
Buy parts from other supplier
Student discount
Hello, how do I choose the color of the led paving stones? I would like them to be blue?
Holyiot YJ-17095 board as a part of PCBWay board order.
Question panel lcd led ips
GIMBAL 1 AXIS STM32F103
Power supply LM723 50V 5A project by John John vu?
ordering trouble
Specifying unilateral tolerances on CNC machined part
does pcbway have a screen compatible with the m5stickc plus 2?
How does components shadowing?
Pin2DMD Evo 256x64 Board ?
Differential thread
New pcb order form makes no sense.
FREHD project
Student discount
ordering trouble
Differential thread
Malcolm Low
RODNEY THAYER
Arno Sommer
