512
[Others] How would I connect an old display and commons to ground without shorting them?
I destroyed a clock radio to turn it into something else, and I used a different display that I already knew how to use. Now I'm trying to reuse the old display, and I've found the commons, bu...
electronics
connect-to-ground
display-and-commons
Sep 02,2020
Joson
