7
447
Maximum copper thickness?
I have a customer who requires 30amp DC current carrying capability. What is the maximum copper cladding thickness that is usually availabe, please?
copper-thickness
Dec 27,2021
Mr.Lee
3342
Plating thickness
What is the thickness of the plating for the different finished outer layer copper thicknesses 1oz, 2oz, 3oz, 4oz 5oz, 6oz?I am asking because I need to know the thickness of the copper in the vias.
plating
copper-thickness
via-copper
plating-thickness
Mar 19,2020
