3344
Plating thickness
What is the thickness of the plating for the different finished outer layer copper thicknesses 1oz, 2oz, 3oz, 4oz 5oz, 6oz?I am asking because I need to know the thickness of the copper in the vias.
plating
copper-thickness
via-copper
plating-thickness
Mar 19,2020
