535
Altium 10: How to specify break away notch in Altium between 3 different board in 50x100mm board
I have Altium 10Which layer to specify 3 board to have break away notch?These 3 boards has same size but different circuit.What clearance between two board (0.5mm each side?) and edge (0,5mm)?Thanks
Altium
design-rule
May 12,2020
power electronics
Pedir solo comoonentes
pcbway plllll
Oportunidad de trabajo
related pcb
PCB is labelled
Hi There I'm Same
IN-16 Nixie Wristwatch
how to use this board
Alice Brown
Julian Eballa
James Youngs
