613
[Others] Relay Output Problem
I'm doing a Sanitiser dispenser with an Ultrasonic Sensor. For every alternate sensing of the hand, I'm getting a brief disturbance signal from the relay. It goes on for a few milliseconds and...
electronics
optoisolator
MOSFET
disturbance-signal
relay-output
Oct 15,2020
Paul H
KhronoSound Audio
john James
LouD _
