6
1818
[PCB Assembly] MCU Flashing service
Hello,I have a board with one attiny85 that requires pcb fabrication, assembly and program upload. Does PCBWay offer flash service for this MCU if i provice the hex file?As other question: Are both to...
attiny85
flash-mcu
Feb 03,2021
Bastian
