5
655
How to keep good thermal contact? Electrically isolating a heat sink?
I'm making a motor driver board with 4 x BTS7960B motor drivers. I want to put them quite close together and dissipate the heat through some thermal vias and into a heat sink on the opposite side ...
isolate-the-heatsink-electrically
thermal-contact
Jan 13,2021
Nikola Krneta
