768
[PCB Assembly] About leadtimes
Hi,I have a small prototype board production with SMT. I want to know how long it would take you to produce 5 boards of 4-layer-PCB's and assembly. All the components would be sourced from ****.&n...
leadtime-assembly
Mar 06,2020
PsElectroBot
