350
Constant current LED driver
I want to power a constant current LED (145mA & 200mA) at 19-21V.Since this will be powered by Li-ion battery connected to a tp4056, which is the most efficient way to boost the voltage from 3.7V ...
Constant-current
Li-ion-battery
LED-driver
Aug 12,2020
Joson
319
Will the led driver burn these two led strips If I connect 2 of these led strips to the Led driver(output: 12v 30A)?
The Led driver (output: 12v 30A) and two led strips of 5m each (Input Voltage: 12V DC, Power: 2A 24W).
led-strips
led-driver
Aug 10,2020
Gorge
