1826
How to check net antenna for vias not connected to other layers. I use Altium.
I have some vias placed on fills and regions, but the vias themselves are not connected to anything on the other layers. I was expecting that Altium's net antenna rule will show net antenna errors...
vias-check
tracks-and-arcs
net-antenna
altium
design-problem
Oct 13,2020
Rebecca Afzal
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
