585
[PCB Assembly]
ESP32 RC Sound and light controller pcb
### 1.Want to get this board wuth all part solder on it looking for 5 board
not-good-with-computer-to-order-it-from-file
help-with-board-order
Oct 30,2021
Krrish Verma
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
