2736
Cannot open properties panel in Altium.
I'm using Altium 20. I have a schematic open on one monitor and PCB editor open on another.In my schematic editor I cannot seem to open my properties panel. It says it's active (ticked in the ...
how-to-open
Altium
properties-panel
Nov 04,2022
Sean Tager
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
