591
[Others] How to convert signals from a raspberry pi to a relay board.
How to use an TXS0108E bi-directional logic shifter to convert 3.3V signals from a raspberry pi to a 5.0V signal to a relay board. I'm trying to trigger a 5 volt relay board using a raspberry...
signal
relay-board
raspberry-pi
Jul 13,2020
Joson
can you make the drawing and the cnc machining for a project I need but I don't have drawing ?
Maximum Dimensions of 3D metal part
POM Gear Wheel production large size M 2,5 280mm diameter
FREHD project
Question LED, backlight and LCD
Looking for Components Library + availability.
Buy parts from other supplier
Student discount
Hello, how do I choose the color of the led paving stones? I would like them to be blue?
Holyiot YJ-17095 board as a part of PCBWay board order.
Question panel lcd led ips
GIMBAL 1 AXIS STM32F103
Power supply LM723 50V 5A project by John John vu?
ordering trouble
Specifying unilateral tolerances on CNC machined part
does pcbway have a screen compatible with the m5stickc plus 2?
How does components shadowing?
Pin2DMD Evo 256x64 Board ?
Differential thread
New pcb order form makes no sense.
FREHD project
Student discount
ordering trouble
Differential thread
Malcolm Low
RODNEY THAYER
Arno Sommer
