406
[Others] How to prevent cables from disconnecting from the screw terminals in a relay module
I'm controlling a lamp with a relay module but I'm worried about the cables disconnecting since I'm working with mains electricity and the cables are very easy to disconnect once screwed t...
relay-module
screw-terminals
cable
Oct 12,2020
Gorge
How to download the gerber?
Looking at purchasing a project but I need more details on what it includes.
Excellent work! This will be amazing in our observatory!
Bonjour Je souhaite commander le PCB Synthesizer UA7KJ Mega2560 V1.1 Il n'y a pas le Gerger pour commander .. est-ce possible ? Merci Marcel GIBELIN f1ge@sfr.fr
Hubcap Insert
I'm a beginner and I want to make a PCB with ESP32-C3 + MPU9250, can you help with the schematic?
capacitors question
Question about the dimension of the self-clinching standoffs for designing sheet metal project.
PS/2 mouse part not working
AMIGA 500 MEMBRANE
Conformal Coating Capability
does it have touchscreen function?
Product ordering
How would I order the assembled board from this project?
Ordering Panel
Which city is PCBWay located in? (for expensing purposes)
electrolytic capacitor question
In my application, the PCB needs to be partially submerged in water. Is there a PCB fabrication option or coating for preventing water ingress into the PCB layers if the PCB is submerged in water?
Flight-Simulator to use for SITL/HITL testing.
Is the "Adapter 2364 - 27128 (by Bobbel)" shard project still active?
Hubcap Insert
capacitors question
AMIGA 500 MEMBRANE
Product ordering
Ordering Panel
