1281
How can I remove the footprint and leave only the Drill pad, a question using Kicad.
Hi all, I was wondering if there is a way to remove the footprint and leave only the Drill pad, in the past I printed another circuit but the footprint outline actually made a connection which I had t...
drill-pad
pcbdesign
remove-the-footprint
Kicad
Sep 04,2020
Kemio
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
