402
A question: what is the impedance of a resonating LC circuit?
1. Some people say that capacitive reactance cancels out inductive reactance, so the impedance of an LC circuit is 0 Ω to its resonant frequency (not accounting for wire resistance).2. Others say that...
resonating-LC-circuit
impedance
Dec 01,2020
myth318
