4307
[PCB Design] In KiCad, How should I designate the flex areas of a rigid-flex board?
I have a rigid-flex design which consists of two rigid sections connected by one flex section. How do I convey to the fabricator which areas I want rigid and which areas I want flex?
rigid-flex
rigid
flex
kicad
Aug 17,2024
dlg Dlg
791
[PCB Prototype] Bend cycles of flex and rigid-flex pcbs
Hello, how many bend cycles can the flex and rigid-flex pcbs handle?
datasheet
ordering
question
bend
bending
rigid-flex
flex
Apr 22,2023
Guang Ning
