993
[PCB Assembly] Part source,
Hi,If I would like to make a PCB assembly with the part : EBC22DCAN-S189from Sullins, is it possible to source the part ? Is the lead time 3 weeks ? What is the unit price for PCBA service ?Thank...
through-hole-assembly
edge-connector
pcba
Dec 19,2020
Pete Dudash
KhronoSound Audio
john James
LouD _
