[PCB Prototype] I need to create a pcb combining an ESP32 with some other components and a display. I also want the plastic design to be created and the electronics installed in it. I am looking for a finished prodct
I need to produce a PCB + Assembled + build the product including final assembly. Can you do that... Please let me know.Warmest regards,Robert Manuel
[PCB Assembly] Washing of PCB Boards after Part Assembly
What is the cleaning process of boards after they have been assembled with components?. Are the washed, and if so how, and using what type of liquids? How dried? Are the air blown as well? Thank you.
[PCB Design] Square holes in PCB. (Or slightly curved edges.)
Hi, I'm drawing a pcb that has 2 small square holes in the middle.I have a few amateur questions about how I should draw them to avoid engineering issues later on.I was wondering if I should draw them...
[Others] How to search for a member.
How do you search for a member/creator? I follow several youtubers that are sponsored by PcbWay and want to look at shared projects. However, I can not see a way to search for a member.
[PCB Prototype] Hdmi screen from old tablet.
Hello, I have a Galaxy tab e 5 tablet. It is so old that cant even open youtube anymore. So i wanted to make an hdmi screen from it. Is it possible? I would be happy if you help me about this project.
[Sheet Metal] [Sheeet Metal] Chamfering and Threading
Hai, Do you provide features like chamfering and threading for sheetmetal parts with thickness >= 4mm ..? or for any thicknes if you provide this feature at all.Thankyou.
[Others] Inquiry About Sponsorship Opportunities
Hi, my name is Alvin, and I'm planning to create a YouTube channel focused on maker projects, particularly in the field of mechatronics. My projects will involve both electrical and mechanical compone...
[PCB Assembly] Do PcbWay have some standard components that i could refer to in my BOM?
Hi, I am making a BOM for my pcb project that i want PcbWay to assemble. I try to follow the spreadsheet suggested by PcbWay (Sample_BOM_PCBWay.xlsx). I am, among others, using some standard passive c...
[PCB Prototype] Hi, Can you guys design a PCB board for me if I give you the datasheet and the STEP file?
[PCB Prototype] If I buy a PCB that someone has posted, what do I need to check on the order to make sure it comes as complete as possible? Basically, does it come with resistors and such
1 ... 10 11 12 13 14 15 16 17 18 19 20 ...
