I would like to get a soap mould printed. Can you print it in PETG? If not, can you recommend which of your available options would be most suitable? The final product needs to handle strongly alkalin...
Hi, i like to create a board for my esp32 devkit edrums project.I like to have 12 input for the piezo pads, every input will be connected with 1M ohm resistor and a zener diode in parallel mode and ev...
I have an old piece of heavy equipment. A control board on it has gone bad that is no longer made. Is it possible to send this in to PCB way and have the board replicated?
Hi,according to the BOM this project contains socketed IC.How will you do assembling?Just placing & soldering the sockets or seating the IC on the sockets as well?What about those parts like conne...
were can get more information about john john vu pcl 86 pcb board. did anyone has build this amplifier.is it possible to have john john vu email adress.i am interested to build this project.merci fran...
