iSpndel_4.0
600
[PCB Prototype] Dose separate DC power require for "LIGHT AND MOTION SENSITIVE LAMP" Circuit?
If "LIGHT AND MOTION SENSITIVE LAMP" circuit run by 220VAC then will it automatically power the sensor and relay or separate DC power needs to apply?Why there are two relays in above c...
PIR-sensor
Relay
DC
220VDC
IR-sensor
Light-sensor
Jul 31,2020
Home Kid
esp32-div project i need t purchase
Good morning. Looking for the link to get the small busbars described for the initial connection between cellls?
Need Help With XL6009 DC-DC Boost Adjustable Module — Output Not Stable?
How does the process of flashing an ESP32 work?
Material selection
Very minimal STM32WLE5JC LoRa node (integrated LoRa) design problem
A Humble Request !
Tda7294 schematic for pcb
3
need to pcb for hotels lock
I need a bigger version of freewheels and sprockets to be used in a prototype?
SHOULD I CHOOSE CPT OR DDP INTERNATIONAL SHIPPING OPTION FOR UK DELIVERY TO AN INDIVIDUAL
Hello I am looking for a diy Christmas light display sequence controller that can be computer programmed
Hello I am looking for a diy project that I can be able to control. My Christmas light to make them animated
Did the low-speed CAN transceiver board work well?
Change to accommodate logic analyzer probes.
form is prompting for length and width measurements
can you give me the smart inverter that can identify the input voltage of a battery like 32V,48V,72V light electric vehicle into a stable 230V, 60Hz AC output. that can identify also the OVL,OVC.
a prototype of a micro controller inverter that can identify the load voltage of a input battery like 36V, 42V, or 72V of a light vehicles into a stable 230V, 60Hz Sinusoidal AC outputs
voltmeter icl7107
Order pcb including wires
KhronoSound Audio
john James
LouD _
