420
Dose separate DC power require for "LIGHT AND MOTION SENSITIVE LAMP" Circuit?
If "LIGHT AND MOTION SENSITIVE LAMP" circuit run by 220VAC then will it automatically power the sensor and relay or separate DC power needs to apply?Why there are two relays in above c...
PIR-sensor
Relay
DC
220VDC
IR-sensor
Light-sensor
Jul 31,2020
Home Kid
I asked a quote to JLCCNC
Peter de Vroomen
gokul kb
