if i have a multi body assembly with 45 parts some big and some small how shall i ask for quote? should i upload every part separately or do i upload one stl file with multiple bodies.
Hi, I have a project where laser cut sheet metal parts will fit into milled slots, but we need to know the tolerance of the sheet metal stock. If we select 2mm stock, does it measure oversized (eg: 2....
We are planning to manufacture a 6-layer PCB with your team, including both fabrication and assembly. I’m looking for a stackup similar to the one in our original design, which I’ve attached for refer...
I am using Altium designer to design my PCB. All the signal and power links on the top metal layer terminate near the die (with pads facing up) for wirebonding.I want to expose a portion of the links ...
. e.g. My current logic analyzer can collect up to 255 samples on 32 channels before or after the trigger at the selected sample rate.I read through the manual and I can't find the answer to this crit...
