hii need a pcbonly available is top bmp image and the top silk.bottom is solid copper.2 layers are connected with vias as seen from the bmp imagecan do this for me ?thanks
In my PCB, I need to solder square pins into circular holes on traces. The pins have basis diameters of 1.4mm and 1.05mm. Which hole diameter should I include in the design: 1.4mm and 1.05mm (assuming...
I got a Question? I bought a Tuner for my Sony CRF-330K 33-Band Shortwave Radio I bought a rebuilt Shortwave Tuner & they didn’t replace the (1) Plastic Gears on the Tuner can I purchase the 1 gea...
how do i get a quote for the pcb assembled? i clicked pcb and assembly but it wants me to input layers from gerber file but i have no clue what to fill in.
Hey!I am interested in assembling the "MBC30 Flashcart | 4MB | FRAM | RTC | Crystal Clear Edition". This is my first time using pcbway so my question is if the Flash Cart is 100% completed a...
I want to design a ~30cm long 4-layer flexible PCB which requires 100ohm impedance match for the differential pairs. It seems like as the dielectric layer is very thin, it's hard to do that. Do you ha...
Hello... I am new to PCBWAY I see a project I am interested in is on your site how do I got about ordering the PCB for this projecthttps://www.pcbway.com/project/share/ESP32_BlueJammer_007f66ee.html
