590
[PCB Prototype]
Stack-Up of 3.2mm 6-Layer PCB
Hello,I am looking for your standard 6-Layer stack-up for 3.2mm PCBs. The dialetric constants would be very helpful as well. Thank you.
3.2mm-PCB
6-Layer-PCB
Stackup
Aug 02,2021
Kfir Maymon
258
[PCB Prototype]
donor board
Do u have donor board number 2060-701477-001 Rev A for WD5000AAJS-22TKA0 date 24 July 2007 ?thx
donor-board
Jul 30,2021
Ed Ouellette
251
[PCB Prototype]
Power Supply TPS7A4700 2 channels without transformer
what-is--the-voltages-and-current?
Jul 30,2021
Ed Ouellette
595
[PCB Assembly]
Chief Engineer
Micro-vias OK?
Micro-via
Jul 30,2021
Ed Ouellette
289
[PCB Prototype]
Where to get parts in Australia
Luca-Dentella
arduino-based
BoosterBoard-10.sch-EAGLE-Version-9.6.2
Jul 30,2021
Ed Ouellette
294
[Others]
MCPCB Aluminum PCB
May I know what material you use on thermal isolation/prepegs?
mcpcb-aluminum-pcb
Jul 30,2021
Ed Ouellette
420
[Others]
how can I get beans
bens
Jul 29,2021
290
[Others]
OpenEEW Node
Hi one of our customers is looking for OpenEEW Node for our research purpose. So we require 2 samples of OpenEEW Node and if it gets through the testing then we may require around 20-25 unit...
OpenEEW-Node
Jul 29,2021
319
[Others]
ARDUINO SHIELD K3NG KEYER
What is the price of this board (including postage to nz)
ARDUINO-SHIELD-K3NG-KEYER
Jul 29,2021
264
[Others]
About sponsorship.
Is pcbway only sponsor for pcbs or pcbway will provide full sponsorship for the project. And when pcbway provide sponsorship for the project.
#sponsorship
Jul 29,2021
68
69
70
71
72
73
74
75
76
77
Internal Splice Broaching?
