[PCB Prototype] MCPCB or Aluminum PCB
May I know what is your standard material you used on the Thermal Insulation layer?
[PCB Prototype] Can you help me identify a part?
I had a part breakoff from a CCTV camera board and I need to see if I can identify it in order to replace it.
[PCB Prototype] Is 0.15mm minimum trace/space considered equivalent to 6mil minimum trace/space?
I have a PCB design with minimum trace/space 0.15mm. In your Online Quote for Standard PCB, is it sufficient to specify "6/6mil", or do I have to specify "5/5mil"?
[Others] Any questions about raspberry pi pico contest?
Share project to get a new pico for freehttps://www.pcbway.com/activity/raspberry-pi-pico.htmlleave your comment here
[PCB Prototype] Technical data sheet for FPC coverlay materials
Hello. Is there a technical data sheet (TDS) that I can see for the coverlay material and adhesive used for FPC prototypes?
1 ... 72 73 74 75 76 77 78 79 80 81 82 ...
