I would like to know if it is necessary to send the gerber of a pcb to be copied or cloned? Could you simply make it with a jpg of the pcb to be cloned? Thank you.
Ya he montado 3 Placas sin que funcione ninguna de ellas, el dispositivo solo envia los datos a Ubidot cuando este se resetea, luego deja de hacerlo para apagarse totalmente minutos mas tarde, voy aca...
Здравствуйте, у меня есть образец не сложной платы 26мм на 43мм , вопрос такой: могу ли я вместо чертежей выслать вам образец платы, один с припаянными деталями, а другой без деталей, чтобы вы по моим...
Hello,I am interested in producing the PCB shown here:https://www.pcbway.com/project/shareproject/Sony_MSX2__128K_RAM_expansion__HB_F1XDJ_and_similar_models_.html However, the design appears to be inc...
I've been using tacky flux to solder small pin-pitch packages with a flat tip, and it's been awesome. But it is quite a terrible time when it comes to cleaning. I've tried 70% isopropyl al...
Need to design a custom flex cable with USB-C male connector. The USB-C connector should be right angle so that it can easily go in the phone's usb-c port. See pic attached for reference.1. What t...
