Hi all,
For a project I created a custom PCB.
It's a LiPo powered PCB with ESP32-WROOM-32E module, Lipo charging module, 3.3V Voltage regulator and MPU6050 Acc/Gyro unit. Charging via USB-C connector. The ESP-32 module being programmed by using a programming header (and external FTDI232 module, to be attached on position “H1:program” in the schematic below.)
After uploading the code and powering via the FTDI232 module, attached to my USB port in computer (LiPo and USB-C disconnected) everything runs fine.
But when trying to power only from LiPo (2000mah) and even when supported with charging power from USB the script________ is triggering a Brownout Detector error. When uploading a blink________ or ‘bare minimum’ script________ everything is working fine om LiPo-only power. My assumption is that the final script________ (using Wifi, BLE, MPU sensor) is triggering the error while consuming to much current? But I don’t understand why I don’t have this issue when powering via FTDI232 module.
Is my schematic correct (looking at the choice of voltage regulator HT7333-7, placing of capacitors etc)? Any suggestions how I could further investigate and solve the error in a future design are really welcome.
Thanks,
Mojies
1 | PCBWay Team | 9 |
2 | weslley ramos | 1 |
3 | Epishko Dmitry | 1 |
Forgot to mention... If you add a couple more diodes, one connected anode to regulator output and cathode to 3v3 rail, and another one connected anode to regulator ground pin, cathode to real ground, you'll stop any nasty backfeeding into the regulator. The first will stop the backfeeding, and the second lifts the regulator output to compensate for the 0.7v drop.
