1279
[Others] Any advice on changing an IR receiver to push buttons.
This is an LED driver which controls an LED strip with a remote and can change the colors/intensity of the lights. It supplies 12v to the LEDs.I want to know if it is possible to replace the IR receiv...
LED
push-button
IR-receiver
Nov 16,2020
DAVIDE
