1453
[Others] How to connect two PT100 to Raspberry pi?
How to properly connect two PT100 (or similar) temp sensors to raspberry pi. I have been googling and found MAX31865 converter but is it the best option? If im not mistaken both sensors would need own...
temp-sensors
MAX31865-converter
Raspberry-pi
PT100
Sep 14,2020
Andrew
Hi , I have a question about the pcbWay contest. ESP32 & display connection
Capability to machine external threads of 5/8-18UNF
Make this circuit pcb with components
Hola!!. ¿Qué costaria este diseño en total? 5 PCB sin montaje, solo las placas. SALUDO
Boss CE-2 by tonepad
Stacking blind uvias with buried vias
Firmware/sources for USB-Joy
Question about different orientation of the stm32F on the silkscreen compared with the one in the blog
Hi, what is the yield strength of Stainless steel 316L. The one that used with the 3d printing, not cnc
amplifier for stand alone push to talk that connect dynamic mirophone headset to baofeng style radio
