1441
[Others] How to connect two PT100 to Raspberry pi?
How to properly connect two PT100 (or similar) temp sensors to raspberry pi. I have been googling and found MAX31865 converter but is it the best option? If im not mistaken both sensors would need own...
temp-sensors
MAX31865-converter
Raspberry-pi
PT100
Sep 14,2020
Andrew
