847
[Others] Display Module: MHS 3.5 inch SPI touch screen with Stylus (Raspberry Pi 4B/3B+)not worked.
Display Module: MHS 3.5 inch SPI touch screen with Stylus (Raspberry Pi 4B/3B+)not worked.I tried many different SD Card image files on Raspberry Pi3B+ and I couldn't get any visual images from ...
Display-Module
Raspberry-Pi-3B+
Raspberry-Pi-4B
MHS-3.5-inch-SPI-touch-screen
Display-Module
Dec 29,2021
Guang Ning
