645
[Others] Raspberry Pi Power Circuit Advice Needed
Looking for advice on improving this circuit. I use a 3S Li-Ion battery into a buck converter to power a Raspi trail camera with an on/off switch and led indicator.I use a largish resistor because I l...
resistor
led
buck-converter
battery
Raspberry-Pi-Power-Circuit
Jul 31,2020
Gorge
