Raspberry Pi Power Circuit Advice Needed
Joson asked Jul 31,2020
Looking for advice on improving this circuit. I use a 3S Li-Ion battery into a buck converter to power a Raspi trail camera with an on/off switch and led indicator.
I use a largish resistor because I like a dim LED. I have a BMS on the battery. Anything I can do to improve this circuit?
  • Your Answer(2)
  • 0
    Move the power switch to the buck's input. Switchmode converters still consume power when their output isn't being used.
  • 0
    One idea is to connect the LED to a GPIO pin as opposed to a power pin. You would flash it once every 5 seconds as a sign of life. This saves you battery power and it lets you know that the pi functions correctly, in addition to the power working correctly.
1 PCBWay Team 4
2 Christian Davies 3
3 Bhanu 2
4 Engineer 1
5 Engineer 1
