6
2420
Room violation in Altium.
All my components show they have violations. When I check them they all state something about a Room Violation. Do I have to have one? Thanks for any help.
pcb-design
components
Altium
Room-violation
Nov 18,2020
Sayanik Mandal
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
