1471
[PCB Design] SMT spacer and Substrate....
We have issue regarding strenght of copper track on substrate. The SMT spacer peels off with copper track after screw fitting. please refer to photo.Request your help on this issue.thanks,AY
Substrate-pcb
Dec 21,2021
Eric Mercado
