769
[Others] Can I solder my heatsink with a 0.3mm copper shim?
Can I solder my heatsink with a 0.3mm copper shim to reduce the gap between heatsink and ihs? I can only find PCB hand solder. can I heat up the shim with solder until solder melt and quickly stick it...
heatsink
copper-shim
solder
Jul 23,2020
Carl
KhronoSound Audio
john James
LouD _
