635
[Others] MCU controlled buck converter?
If it's possible to control the power output of a 12V/150W heating element using some sort of buck converter circuit. It should step down the 12V input to various voltages required to vary the out...
switching-FET
PWM
power-output
heating-element
MCU
buck-converter
Oct 03,2020
Hugo Hu
How to download the gerber?
Looking at purchasing a project but I need more details on what it includes.
Excellent work! This will be amazing in our observatory!
Bonjour Je souhaite commander le PCB Synthesizer UA7KJ Mega2560 V1.1 Il n'y a pas le Gerger pour commander .. est-ce possible ? Merci Marcel GIBELIN f1ge@sfr.fr
Hubcap Insert
I'm a beginner and I want to make a PCB with ESP32-C3 + MPU9250, can you help with the schematic?
capacitors question
Question about the dimension of the self-clinching standoffs for designing sheet metal project.
PS/2 mouse part not working
AMIGA 500 MEMBRANE
Conformal Coating Capability
does it have touchscreen function?
Product ordering
How would I order the assembled board from this project?
Ordering Panel
Which city is PCBWay located in? (for expensing purposes)
electrolytic capacitor question
In my application, the PCB needs to be partially submerged in water. Is there a PCB fabrication option or coating for preventing water ingress into the PCB layers if the PCB is submerged in water?
Flight-Simulator to use for SITL/HITL testing.
Is the "Adapter 2364 - 27128 (by Bobbel)" shard project still active?
Hubcap Insert
capacitors question
AMIGA 500 MEMBRANE
Product ordering
Ordering Panel
