496
[Others] Does a single supply amplifier only drive a speaker in one direction?
I have a question. The input and output of a single supply amplifier are AC coupled with capacitors.AFAIK the caps just filter the DC component from the signal , they do not magically center the signa...
AFAIK
low-frequency-audio
speaker
supply-amplifier
Oct 09,2020
Bobby Iridium
