498
[Others] Does a single supply amplifier only drive a speaker in one direction?
I have a question. The input and output of a single supply amplifier are AC coupled with capacitors.AFAIK the caps just filter the DC component from the signal , they do not magically center the signa...
AFAIK
low-frequency-audio
speaker
supply-amplifier
Oct 09,2020
Bobby Iridium
Hi , I have a question about the pcbWay contest. ESP32 & display connection
Capability to machine external threads of 5/8-18UNF
Make this circuit pcb with components
Hola!!. ¿Qué costaria este diseño en total? 5 PCB sin montaje, solo las placas. SALUDO
Boss CE-2 by tonepad
Stacking blind uvias with buried vias
Firmware/sources for USB-Joy
Question about different orientation of the stm32F on the silkscreen compared with the one in the blog
Hi, what is the yield strength of Stainless steel 316L. The one that used with the 3d printing, not cnc
amplifier for stand alone push to talk that connect dynamic mirophone headset to baofeng style radio
KhronoSound Audio
john James
LouD _
