318
For PMSM, how is 'field weakening' achieved?
I don't know how the field is actually weakened. For a PMSM motor for example, how can the field be weakened? Is it done through the phase wires or externally?
phase-wire
field-weaken
PMSM
Nov 03,2020
Dennis Farquhar
Change my E-mail address
How do you make something?
Request to use project
PCB+ assembly
Stephen Newport
