-1
5
32932
[PCB Assembly] EAGLE: How to generate pick and place file
How do I generate a pick and place (aka centroid) file in the correct format for PCBWay using EAGLE? Thank you.
eagle
centroid
pick-and-place
assembly
Dec 06,2022
