I need a pcb design and schematic diagram that will power my projectA reachergeable power control DC to DC1. 5v DC charging port input2. 3.7v to 4.2v battery Input3. Battery Output for laser pointer 2...
we are looking to buy 2 layer Flex pcb's, 30 pcs 0.2mm thickness, small pcb's//is it possible to send you order, and how long need to waite for delivery actually now?thank you,keep strong...
Hello I make a PCB project with sprint layout 6.I would PCBWAY build the PCB and assembly the component on it.You claim a XY centroid file but I don't know how to obtain it.Do you have the solutio...
Hi! A great job! As usual :). A simple question.. How the cad works with the two banks? Do we need to split a 1024 bin file or the software will do it itself? Thanks! It's really a great cart!!
Hi, we are planning to order several boards which have 1mm thicknes and/or 2 oz copper thickness and/or solder mask colors other than green. How many days is ithe process extended from the regular sch...
