[Others] can u print our company anme on t he pcb sir
[PCB Prototype] P-CAD 2006
Can you make a board designed in P-CAD 2006?
[PCB Prototype] Opera cake
Hello there I'm Riccardo Giuntoli writing from Spain. I'm interested in the Operacake project and I want one board.https://github.com/mossmann/hackrf/wiki/Opera-CakeCould you please assemble i...
[PCB Prototype] Pcb Design and garba file download
Please what's app no and email address
[Others] Stack up for 2 layers
Hi, this is Raul, can you guys give to me the standard stack up for 2 layers .8mm? standard material and dielectric constant?Tks in advance!
[PCB Prototype] IPEX Cabline SS connector
Hello! Is it possible to order PCB assembly with the following item:I-PEX 20374-R14E (14-pin receptacle, see https://www.i-pex.com/product/cabline-ss)
[Others] PCB new category
On "Share&Sell" why not add field "Seismology" as available category?Regards, Michele.
[PCB Assembly] i want pcb
dear sir,I want 4000watt power amplifier board so can you give me this pcb
[PCB Assembly] want to know about pcb with mounted components
I have a new pcb to be produced, but I would like to know if you can make it with a welded component, in this case an Altera epm7032stc44-10 supplied by you.
[PCB Prototype] Stackup Layer Structure
Hi,I will design a PCB after that send you to produce.However, I'm not sure I set the stackup you produced right. The core should be the middle part, and the dielectric coefficient is 4.29 fo...
