Goodmorning,is there available table or suggested values for minimum distances among SMD/PTH packages?SMT/PTH device spacing depends from technology and assembling equipment, I would like to make PCB ...
I have Altium 10Which layer to specify 3 board to have break away notch?These 3 boards has same size but different circuit.What clearance between two board (0.5mm each side?) and edge (0,5mm)?Thanks
Hicould you please suggest me 8 Layer Stackup with 3 inner signal layer?i need impedance control (50 ohm single ended and 90-100 ohm on differential trace)
I'm a student from ETH Zürich and I need to print and assemble 2 PCBs. How long does it take to print, assemble and ship them to Switzerland?Thank you very much for your attention.
Hi, Im new to electronics and can just about solder two wires together.I was looking at your 555 adjustable time light blinker , it is perfect for adding lights to my 1/48 scale aircraft mod...
