[PCB Prototype] Aluminum pcb for high power LEDs
Is it possible to produce Aluminum pcb for high power LEDs?
[PCB Prototype] Plating thickness
What is the thickness of the plating for the different finished outer layer copper thicknesses 1oz, 2oz, 3oz, 4oz 5oz, 6oz?I am asking because I need to know the thickness of the copper in the vias.
[PCB Prototype] Minimum slot size
I need to make a small slot in a PC board. How narrow of a slot can you make? Can it be made it as a curved (radiused) slot ?
[Others] Parts required for BE6502 Build a 6502 computer (SBC-module revision A)
Hello:I've just received the PCBs from the BE6502 Build a 6502 computer (SBC-module revision A) project created by Tor-Eirik Bakke Lunde. It is nicely laid out. I have a couple of quest...
[PCB Assembly] Pin2dmd 128x32 assemblly
Bonjour si je commande cela est ce que j'aurai le modèle assemblé entièrement ?https://www.pcbway.com/project/shareproject/PIN2DMD_EVO128x32_RGB_LED_Dotmatrix_Pinball_Display_Controller.htmlMerci ...
[PCB Prototype] Amplificador 400
Tienen alguna descripcion tecnica del amplificador?Ud. venden laa placa y los componentes?Gracias
[PCB Prototype] Need PCB Ruler with our logo
Hi , Is it possible to make PCB ruler with our logo? I need same as Product ID:LP132PCBWAT Ruler-Red
[PCB Prototype] PCB order and delivery
Hi, is your factory working now, and delivery to Ukraine via DHL?
[PCB Prototype] Delivery time
Good afternoon. Please indicate the production time of the PCB and the delivery time to Russia.
[PCB Prototype] question about delivery
Hi, im in a hurry with some pcbs we need for a project, I want to know the delivery time that you have right now for pcbs to Mexicothanks in advanceerick s
