[PCB Prototype] hacer placa
hola quisiera hacer un proyecto con el TDA2822 pero lo tengo en esquema no se hacer el circuito como ustedes lo piden que debo de hacer gracias
[Others] it is about the kind of the PCBs
what is the difference between the working board and blank board?
[PCB Prototype] Заказ потерян
Заказ потерялся и что теперь делать
[PCB Prototype] shopping sahopping
hi.I am writing from turkey.at 15.12.2018,I did a $ 8 shopping from the aliexpress pcbway site.but my balance was not unloaded.I'd like you to take care of it.
[PCB Prototype] Patch antenna with mashroom EBG manufacture
We have already designed a patch antenna with mashroom EBG on it working at 10 GHz. Is has the following properties:Permittivity = 2.5 Substrate:Roger Ultralam 2000(losy), loss tangent...
[PCB Prototype] is it possible to order this one, and what is the prize?
https://www.pcbway.com/project/share/Lucky_Resistor_Snowflake.html
[PCB Prototype] shipping cost
Hi, My name is Laszlo from Hungary. I am interested this PCB: https://www.pcbway.com/project/shareproject/mini_4S_DIY_PowerBoard.html My question is, how much the delivery cost and the ...
[PCB Prototype] Can I reupload gerber files to my shared project?
Hi, my shared project https://www.pcbway.com/project/shareproject/Arduinoflake_PCB.htmlhas an error in its gerber files, can I somehow reupload the gerber files to fix this problem?Thanks you.
7answers
[Others] Question about the front panel Synthesizer UA7KJ ArduinoMega2560 Si5351 TFT3.2 mod R2AJI v1.1
Hello!I would like to ask if I can order the board from the link below with the size of 220x125 mm.https://www.pcbway.com/project/shareproject/Synthesizer_UA7KJ_Mega2560_Si5351_TFT3_2__mod_R2AJI_v1_1....
