[PCB Prototype] USB ввод магнит
нужна помощь в преобразовании файла PCB в Gerber.у самого не получилось.
[PCB Prototype] about the 18650 pcb board
the last time l watched your video about the pcb catching fire or getting hot, l think the problem is because you placed the 18650 directly on the pcb board. when charging or discharging the pcb will ...
[PCB Prototype] CrossBow Classic PI PCB
Hello Do you sell CrossBow Classic PI PCB???Thanks!
[PCB Assembly] Through-hole design vs. SMD assembly service
We have used PCBWay many times for PCB fabrication and are very happy with the results. Design has always been using through-hole components which we assemble by hand ourselves.I would like to o...
[PCB Prototype] электричество для каждой семьи
здравствуйте каким образом я смогу получить спонсорскую помощь для создание электрической цепи замкнутго действия по системе Тесла
[PCB Prototype] surfmaster pi micro
Boa tarde, como fa?o para compra essa placa do surfmaster micro ?
[PCB Prototype] Draw Software
I want to know if they can process a file in Corel Draw, and if not what is the type of file they need to process
[PCB Prototype] Mega2560 Si5351 TFT3.2 v1.1
Hi.On the page of the pcd board Mega2560 Si5351 TFT3.2 v1.1. there is no documentation. There is a link to a web page. That link is for version v2.0.I would need the information of that assembly, or t...
[PCB Prototype] Transparent PCB
Hi ,could you able to produce with transparent pcb model instead of standard PCB model(fr-4)?
[PCB Prototype] How to add dimension and milling layers to a brd or gerber using eagle 9.2?
