1answers
[PCB Prototype] 2-Layer Stack-up Breakdown
What does the stack-up look like for a 2-layer 1.6mm thick board?
1answers
[3D Printing] Sega NOMAD shell
Roughly how much did this NOMAD shell cost?, looks amazing
1answers
[CNC Machining] Low tolerance borehole in machined part
I'm looking to create a part with a very precise borehole with a radius of 3.2316 mm. The Goal here would be 1/100 mm tolerance or even better 1/1000 mm, depending on possibility and pricing. I was ju...
1answers
[Others] Official Bat Detector USB Microphone v2
I’m trying to find “Official Bat Detector UCB Microphone v2” (first hit if you search for “bat detector”). I get an error if I try to go to that link. The URLis https://www.pcbway.com/project/sharep...
1answers
[PCB Prototype] How to order
Hi,How can I order manufacturing of this project, what would be the cost?<a href="https://www.pcbway.com/project/shareproject/DIY_Advanced_Plasma_Rife_Machine_b9911017.html"><img src="https:/...
1answers
[PCB Assembly] Do you offer pre-flashing service for ESP32 modules with our custom firmware?
Hello,We are planning to assemble around 100 units of a product that uses the ESP32 module. Do you offer a flashing or pre-programming service where you can upload our custom firmware to the ESP32 mod...
1answers
[Components] Verification if you can Procure Certain USB-C Connector
I would like to ask if you will be able to procure one of the following USB-C connectors, as I want you to assemble them in a future project:https://www.digikey.com/en/products/detail/assmann-wsw-comp...
0answers
[Others] How to use *.kicad_pcb files.
I had to re-install KiCad and lost all of my projects. I've downloaded all of the boards I've ordered. I've not able to use those files in KiCad or PCBnew. In PCBnew, the file selector is *.kicad_pcb,...
1 2 3 4 5 6 7 8 9 10 11 ...
1 PCBWay Team 8
